Home > General > MY11 has developed the squeak of all mother Beeping squeaks
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Car is going in dealers tomorrow..... Car was parked up at the point to point yesterday, I came back to it today as it was left in field over night due a drink infused day. Started to drive away and all the way home it has squeaked.
Noise is coming from drivers door area, cant be heard from outside so im stumped to what it could be.
Sad Smile
Post #297876 Mon May 02 2011 7:28pm
Royle
Scotland
What speed are you going when it happens? My wife's cars rear wheel was squeaking, took it to the garage and it turned out to be a wheel bearing. But if it is that I'd imagine you could hear it from the outside. I may be well off but just a suggestion.
Post #297878 Mon May 02 2011 8:02pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
The rear discs are quite good at picking up small stones , I picked one up at Christmas on a drive down to London , was going to phone landrover assist halfway down, then it suddenly stopped. Not had it since , but I've heard it is quite common.
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #297886 Mon May 02 2011 8:18pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Its not a stray champagne cork in the side pocket is it Laughing
Post #297888 Mon May 02 2011 8:51pm
Foxy, have you been cleaning the inside of your door sill with that carnauba wax i gave you by any chance have you?
Post #297890 Mon May 02 2011 9:04pm
drdelrrs
Foxy,
Few questions....
Since you were in a field, it might be moisture (small chance) or...
1 does sound change as you drive
a) in line with wheel rotation speed or
b) with engine revs
2. Does it change if you use the brakes.
if answer (a) could be stone, twig caught in brake disk or brake disc shield.
If (B) could be twig, grass, rope, bridle, horse and rider !!! etc caught in a drive belt ( not too likely)
If sound is some between engine speed and wheel speed you may have trapped a twig etc between a drive shaft or prop shaft and body work.
If answer is number two might be stone in disc.
If none of above try electornic park brake (let car roll slowly in gear (Drive) select nuetral (not park) and switch on park brake. Repeat process in reverse - if this cahnges the sound you've something caight in the park brake system.
Or if nowt else, could it be the Knight you snared and chained to the towbar has lost his amour (amor)!
Post #297893 Mon May 02 2011 9:33pm
It might be linked to this Thumbs Up
Post #297894 Mon May 02 2011 9:55pm
Siberianfox
Hmm it sounds like an old bed stead!!! Only happens over bumps or undulating ground.
Ive checked for any stray suitors or knights in shining armour ( i should be so lucky).... and unfortunately the only thing I found under my car was a full size spare wheel.
It may sound odd but it does sound like its coming from the glass, almost a little "whistley", if a squeak can be described like that !
So my dealer is going to have look at it for me today. I knew a months trouble free motoring was a little too much to ask from LR. Sad Smile
Post #297904 Tue May 03 2011 8:56am
ChrisP
With a bit of luck it may just need a good underbody jet wash to get the fine grit and gravel out of the suspension,transmission and steering components after your little foray Whistle MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #297906 Tue May 03 2011 9:20am
Siberianfox
HMM we will see .... Im hoping that could just be the case. well see !!!! Smile
Post #297908 Tue May 03 2011 9:49am
And the cause was ????
Post #297926 Tue May 03 2011 3:27pm
Siberianfox
Just sat in dealership now they think its coming from within door so there just cutting her open as we speak she is on the operating table now ! Smile
Post #297928 Tue May 03 2011 3:41pm
Deep breath !!!! It won't hurt Big Cry
Post #297929 Tue May 03 2011 3:53pm
Siberianfox
Although some news on the colour siberian silver is that its been pulled so not many motors going to be in my colour !
I'm hoping its just a squeaky door card anyway Smile
Post #297930 Tue May 03 2011 3:55pm
ChrisP
Could be a water vole that was scooped up from the river and got its head stuck
Rolling with laughter MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #297934 Tue May 03 2011 5:04pm
