![]() | Home > Technical > need a new alternator for rrs |
Its a good starting point, have you checked all your wires to the alternator and check to see if you battery terminals are tight and clean, it might be your battery that is |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
If you get the car started again and have access to a multimeter then you can test to see the alternator is charging at the battery terminals. |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
Are you in AA as they would test it for you and check battery |
