![]() | Home > General > Snow Foaming - do I need to use it? |
Royle Member Since: 24 Nov 2010 Location: Perth Posts: 211 ![]() ![]() |
I've used it on my first Sport (which was Silver) and my last Sport which was Red and worked wonders on each of them. It's not just for black cars, all it does is loosens the dirt. Colour doesn't come into the equation. I think it's just for ease of cleaning and getting in nukes and cranny's |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Living where I do mine gets covered very quickly in a layer of fine millstone grit which is like carborundum,using snowfoam takes all this loose layer off before i use a mit so lessens the risk of scratches.
I took the FFRR into the local guys yesterday as I drove through a lots of potholes that had freshly been filled with a gravel and tar mix that has softened in the sunshine and I had tar spots all down both sides. They used their special Autoglym mix in a hot/ steam wash with snow foam and then left it for 5 minutes to do it's work. Result, no more tar, very impressed and even better it didn't cost any extra over the usual £5 for a normal wash. This is where I now regret having ordered a white car for my next one......... at least you could hardly see the tar on a Stornoway Gray car - on a Fuji White it's going to be a whole load worse 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Yup Tim, I get lots of tar spots. But product called Tardis takes care of it but it takes off any wax on there too... |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Tardis is a great product |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
First time I bought a pressure washer I used the provided mixing lance to snow foam the car. Result was very poor and found out that all I was doing was spraying the car with soapy water. Bought a proper snow foam lance and the result was an eye opener. The proper snow foam lance aerates the foam and covers the car in clinging foam which when washed off left very little dirt to remove with a wash.
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
Tardis !!! just buy the cheapest margarine you can rub it over the tar wipe it off and hey presto no more tar and does not remove the wax ! 2014 5.0SC AB Gone 5.0 SC |
i've not heard of that one before |
I once did the same to explain why I came back from a stag night smelling of Baby Oil |
