Home > Maintenance & Modifications > Tyre Pressure Monitoring System
Jonny Fresh
Will this still work if I swap my 20" wheels to 22" Overfinch?
Post #295896 Wed Apr 13 2011 4:14pm
Tim in Scotland
Only if the Overfinches also have the TPMS bits fitted to the rims, otherwise you will have a permanent warning light on the dash 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #295924 Wed Apr 13 2011 7:30pm
TPMS Explained
http://tooldesk.com/blog/?p=252
Post #295934 Wed Apr 13 2011 8:46pm
Jonny Fresh
I don't fancy that!
Is it possible to retro-fit these bits?
Post #295956 Thu Apr 14 2011 7:55am
Jonny Fresh
Re: TPMS Explained
Ady, if mine is the sort that goes off revolutions of the wheel I should be ok shouldn't I?
Post #295957 Thu Apr 14 2011 7:56am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I don't fancy that!
Yep, I fitted a second set of TPMS sensors to my 19" wheels €35 each for the sensors and they replace the valve stem. but you better check that the sensor fits inside the Overfinch wheels as it depends on where the valve stem hole and how big it is. Sons of dogs come hither and get flesh
Clan Cameron
Post #295958 Thu Apr 14 2011 8:05am
Jonny Fresh
I don't fancy that!
Cheers Alicatt, where can I buy these from?
Post #295959 Thu Apr 14 2011 8:13am
Alicatt
I got mine from my local LR dealer, Landrover Hasselt about 3 years ago Sons of dogs come hither and get flesh
Clan Cameron
Post #295969 Thu Apr 14 2011 8:55am
Jonny Fresh
Great, I'll speak to dealer Thumbs Up
Post #295970 Thu Apr 14 2011 8:58am
Jonny Fresh
Just had phone call from dealer......apparently I cannot put the Overfinch tigers on because the pressure monitoring system will not work......he says they are machined into the wheel!
Big Cry
Post #296113 Fri Apr 15 2011 10:21am
Tim in Scotland
Might be an idea to get the dealer to plug the car into his system and disable the TPMS then, at least you won't have chimes and warning lights all the time - you might be able to twist his arm for a free tyre pressure gauge too! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #296138 Fri Apr 15 2011 12:09pm
Jonny Fresh
2 options now, 4x4 tyres are saying they can supply and fit monitors, or.......just cancel the TPMS all together
Post #296139 Fri Apr 15 2011 12:10pm
Tim in Scotland
Since ordering my new car with TPMS I'm having 2nd thoughts about it now, problem is my new car doesn't have a spare wheel at all, just a can of squirty stuff that apparently can fix a slashed tyre Rolling with laughter 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #296140 Fri Apr 15 2011 12:13pm
oldcro
Scotland
I have TPMS on my MY2011 which works fine with the original wheels, and when I put different wheels on (winter tyres) I do not get a permanent warning. On start-up it just flashes a warning notice for a few seconds saying TPMS not working with no permanent warning light on the dash.
Post #296141 Fri Apr 15 2011 12:21pm
Tim in Scotland
Thanks for the clarification 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #296142 Fri Apr 15 2011 12:31pm
