Home > Technical > Wheel nut sheared !
skippy zermatt
United Kingdom 2009 Range Rover Sport TDV6 HSE Zermatt Silver
Wheel nut sheared !
Grrr..
Was replacing one of my rear wheels today - did a final round of 'tightening up' and one of the wheel nuts sheared !
It has left the domed section very well in place, but the hex section has sheared off.
Any bright ideas on just how involved this will be to resolve? I presume that the stud will need to be drilled though to release the wheel, then (I hope) a new threaded stud can be fitted on to the hub section?
I guess I was just a bit to used to Defender wheel nuts and used too much oomph, maybe need a torque wrench instead of the long-handled beastie in the standard toolkit
In the meantime, hoping not to get a puncture... Rod
Post #294816 Sat Apr 02 2011 9:02pm
panda
I' ve cut damaged / broken nuts out without damaging stud with starrett cutter remove drill from holder to centre wrap masking tape around for snug fit in wheel and drill slowly. Hope this helps.
Post #294857 Sun Apr 03 2011 9:07am
skippy zermatt
Thanks, that sounds like it might work. I feel that this is either going to be a very easy fix if done in a cunning 'bush mechanic' way, or the LR franchised dealer will find a reason that I will need to replace half the transmission!
Cheers, Rod Rod
Post #294981 Mon Apr 04 2011 2:15pm
muddywheels
Milk Float Man
On a 2009 you should be still under warranty - I would go back to dealer - sounds like faulty components Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #295004 Mon Apr 04 2011 6:04pm
drdelrrs
I agree with Muddywheels - if you were using the Sport's wheel brace you should not be able to shear the stud; get back to the dealer and get the set changed.
Post #295025 Mon Apr 04 2011 7:22pm
skippy zermatt
Very Happy All sorted and free of charge too ! Have put a torque wrench in the car to prevent recurrence and given up eating spinach. Rod
Post #295400 Fri Apr 08 2011 9:17pm
