![]() | Home > General > Gear Select Drive V Sport mode |
Sport mode would be faster as it holds the gears to higher up the rev band before changing gear and also locks out 6th whereas just leaving it in D would cause the box to change up at the programmed revs and also slide the car into 6th at about 55mph - 6th is an overdrive gear so acceleration would be slower. Not sure if kick down would be any faster in full auto mode. You might even find manually shifting (commandshift) in Sport mode is even faster than letting it change gears itself in sport mode!
| ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392
Not sure if its true but have heard that sand mode is faster off the mark. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
You could be right there Chris - IIRC sand mode now pulls the car away in 3rd gear too so less gear changes on the way as well! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Nice But Dim Member Since: 15 Oct 2010 Location: Kent Posts: 61
Thanks for that explanation Tim.
Is the gearing different for an S/C like yours - must admit I rarely use the command shift in normal driving with a TDv8 but its is very useful off road when using the TR and manual shifts. On the road kickdown manages OK for most sudden requests for some more speed 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| Vadim Member Since: 20 Apr 2010 Location: London Posts: 855
Tim,
Vadim, that's a very good question and extremely hard to answer! From a comfort and economy point of view the FFRR wins hands down but with the 3.6TDV8 the FFRR's handling is nice but it doesn't handle as well as the 3.6TDv8 RRS with the DR. LR have cured that with the 4.4TDv8 as it has the latest version of DR and it is very very good indeed - ride is slightly firmer but that could also be put down to the 20" tyres that the FFRR now comes on. A better person to ask would be TBoner as he has a 4.4 TDv8 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Interesting, thank you. Vadim A. |
