![]() | Home > Technical > Driving Style |
IIRC LR advises in the owners' manual that there is no "running-in" period but for the first 600-1000 miles to avoid high revs (exceeding 3000 RPM) and to avoid allowing the engine to be in a high gear at low revs (as it's an auto really the only way you can do this is to be in "command-shift" and even then it will shift if it doesn't like it). Seeing as 70 is about 2100RPMs then one long trip on the motorway (eg London to Newcastle and back) would achieve that. Also check you oil level carefully, in the first 3-4 weeks the engine block in a new TDv6 can absorb quite a bit of engine oil (LR reckons 1 litre in the first 600-800 miles is normal) and then (in my exeprience of "running in" 2 TDV engines) it will not use any more. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks
