![]() | Home > General > Front wishbone ball joints. |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
mine had a bit of movement so i changed the ball joints to the new uprated ones, also put the new body dampners on
V8TDSPORT Member Since: 09 Mar 2011 Location: Rutland Posts: 38 ![]() ![]() ![]() |
My knocking noise came from the anti roll bar brushes. Getting them fix next week. Ask your local garage to have a look at them RRS TDV8, 22 rims, Privacy Glass, Premuim ICE plus Leather, Sun Roof, Stornoway Grey.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Did you just change the ball joints or replace all the wishbone though?Was it a warranty job and any idea of cost involved? |
RRS PIMP Member Since: 05 Nov 2008 Location: London Posts: 110 ![]() ![]() |
I went through two sets of anti roll bar bushes and the knock kept coming back after a few months, finally changed the lower wishbones and the knock has gone completely. At the time it was cheaper for me to change the complete wishbone rather than trying to change the bushes in the wishbone, worked out cheaper. New Wishbone comes complete with new ball joints.
scott7 Member Since: 20 Apr 2009 Location: Scotland Posts: 282 ![]() ![]() |
Mines had three sets of arb bushes, noise goes away for a few thousand miles then comes back again, went into dealership recently and they told me it needs the damper kit fitted, which may or may not cure he knock but was not covered by the £900 warranty I just put on it as it was a modification, I argued this possible cure should surely be done foc as a recall, bad show from land rover. |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
I have had arb bushes replaced twice and dampers fitted under warranty on my MY10 and its only got 10k on it, last done in November and they justed started knocking again, so dampers wont cure the problem |
Thanks JC1, no point spending well over £100 if it's not going to cure the problem. |
