![]() | Home > General > WHICH TRANSMISSION OIL FOR AUTO GEARBOX? |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 ![]() ![]() ![]() |
illhave a look ta |
Still cant find it |
Can someone please explain in laymans terms how to use the search facility properly, everytime i try a search i get everything but what i'm searching for ![]() |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 ![]() ![]() ![]() |
same here ![]() |
Hi all. Ok just changed the Transmission oil. The Land Rover Dealership told me on the phone that the transmission holds 9.5ltrs . Well i drained the oil out nowhere near 9ltrs came out ..I then refilled the box started the engine & went through the gears 3-4 times. Then drained all the oil back out I then refilled the transmission approx 2 ltrs on the second fill. Drove it home & at the moment no shunts |
Which oil did you eventually use? |
Millermatic ATF DM |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
hi sorry guys martin hasnt replied back to me regarding how to put up that link i have in a pdf form
Filled it up until the oil came out of the filler so fingers x.. Have just drove it & it still shunts but not as bad. ![]() |
Ill live with it aint gonna bother to flush it again . will have to find out how to do the gearbox update Patch.. |
Cheers ![]() |
Ok Took the RRs into AllTrack 4x4 the bloke checked i had filled the transmission up properly. It was abit low!! anyway he done the latest transmission updates (Wendsday) Cost me £45.00 & it seems to be all ok |
