Home > Technical > Drive mode
Page 2 of 3 <123>
tony harker
England 2005 Range Rover Sport TDV6 HST Arctic Frost
Siberianfox wrote:
Any luck yet ?
not yet mate still in leister working setting off about 10 in the morning dont no what time i will be home haha 50 mile an hour all the way . strait to garage and a digonstic on it.
Post #293566 Thu Mar 24 2011 10:05pm
simon1233
There are so many systems that can go wrong with these cars. Hope it is something simple (and more importantly cheap) the you can get back to enjoying your car
Post #293604 Fri Mar 25 2011 12:29am
tony harker
cheers mate let you no the outcome and cost in the next couple off days . Thanks for the help lads good forum keep it up.
Post #293618 Fri Mar 25 2011 7:31am
tony harker
got back ok any way that was a big weight off me head . drived perfect in manual mode so hope its not anything to serious
Post #293733 Sat Mar 26 2011 10:46am
Tim in Scotland
When was the last time it's gearbox oil level was changed - LR claims it's sealed for life but it has since transpired that that is 3 years ie the life of the warranty! You may find a flush through and refill with new oil by a gearbox specialist will work wonders for the shift 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #293734 Sat Mar 26 2011 10:53am
tony harker
hi guys right the garage i go have put it on the diognostic and came back the two e g r valves have gone . said they are going to cost 600 pound all in do you think that is about right or just pay for the dioynostic and buy my own and get another garage to do it . e g r valvels are going for about 185 for one ? on ebay.
Post #293788 Sat Mar 26 2011 7:40pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
blank them off no more problems with the egr valves Thumbs Up
Post #293790 Sat Mar 26 2011 7:46pm
simon1233
EGR valves are available on eBay for about £125 per side. If you have an older car (pre MY07 IIRC) you can blank the valves. Blanks are available on eBay for around £10 but I read on the disco 3 site that a 2pence piece is the ideal size Whistle
Post #293796 Sat Mar 26 2011 8:29pm
Bloody hell its getting cheaper to blank them off 2p now Laughing
Post #293817 Sat Mar 26 2011 10:12pm
tony harker
my car is a 55 plate so i can blank them off , but wouldnt that afect the peformance off the car ? yes seen them egr valvels for 125 each
Post #293864 Sun Mar 27 2011 5:14pm
tony harker
simon if i blank them off how will that sort the gear change in auto?
Post #293865 Sun Mar 27 2011 5:23pm
simon1233
Hi Tony
I have no idea if blanking the valves will rectify the problems you have had with the gearbox shifting in auto?
Possibly the car is recognising that the valves have failed and is in 'limp mode'? I am a little out of my depth here Whistle
Regarding the performance the info on the D3 site seems to be positive overall, they seem to think that the blanked engines run better, the only thing you notice is a slight increase in emissions, but apparently not enough to fail an MOT.
For the sake of 4p and a couple of hours with a spanner you could try to blank the valves and see if the system resets itself and then if the gearbox starts to shift properly again. There are comprehensive instructions on the D3 site, or just try googling 'disco 3 egr valve blanking'.
Personally I had 1 EGR valve fail at christmas, the symptoms I got was a complete lack of performance under 2500 rpm - gearbox worked normally tho'. Happily my car (also a 55 plate) has an extended LR warranty so the valve was replaced without costing me anything.
Let me know how you get on
Simon
Post #293877 Sun Mar 27 2011 9:39pm
tony harker
thanks for that info mate will let you no the out come cheers
Post #293890 Sun Mar 27 2011 10:17pm
SRE
Spain
Get the Auto Box oil filter changed.
Syd
Post #294183 Tue Mar 29 2011 8:32pm
tony harker
600 pound Big Cry all done running good again
Post #294758 Sat Apr 02 2011 9:09am
Page 2 of 3 <123>
