![]() | Home > Maintenance & Modifications > satnav discs |
Pm sent |
dannyRR Member Since: 10 Nov 2009 Location: XR3i and white stiletto country Posts: 19 ![]() ![]() ![]() |
thanks. |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
On a related note, does anyone know how to decompile/recompile the DVD to remove the |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 ![]() ![]() |
sorry to hi-jack the thread but i have a 2007 hse and was thinking about updating my sat nav,is it just a case of popping in a newer disc.believe the reader is under the passenger seat??? |
Hi Smurf
The black plastic panel at the front base of the passenger seat also just pulls off (held on by 4 grips) if you do not fancy grabbling from the rear |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
I upgraded from 2007 disk to a 2009/2010 and to be honest didnt see an improvement in availalble locations, current road layouts and issues with roads missing that are 20 years old!! With the poor logic used to drive the route direction; next time its no to a factory installed satnav - TomTom at less than £200 is far better. Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
boab Member Since: 06 Apr 2011 Location: Edinburgh Posts: 1 ![]() ![]() |
I've picked up the 2010 disc from ebay. As a total newbie to the model and the maker, why won't the 3 disc nav set up from my mothers freelander work on my '07 HSE?
Please tell, did it work & if so how much better is it? Thanks syd |
i set the seat right forward and high as possible and fumbled about and installed disc that way - when i pulled the front cover off it snapped 2 of the clips ![]() |
craneboy Member Since: 17 Feb 2011 Location: North Wales Posts: 111 ![]() |
Having come from a FL2 myself, the FL2's sat nav system is way better than the RRS (mine '56). Wonder if you could transplant the Fl2's system into the RRS ? Andy |
I may have a set of f2 2009 or 2010 discs somewhere...but i you dont get cd's on the 2011 rrs so i couldnt test them Mike
