![]() | Home > Maintenance & Modifications > Sidelight Replacement |
| mobbster Member Since: 15 Jan 2011 Location: worcestershire Posts: 36
Hi Chris
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
Yeah the entire process was simple except getting the damn bulbs out the actual holder i thought they were going to break at one point and leave a bit stuck in the holder so i decided to stop. |
Chris i assume you took the headlight out to do this, did you try to twist the bulb holder to get the bulb out? Or did you just try to pull the bulb holder out? |
Ady i meant the bulb from the holder not the holder from the headlight mate.
Did you try and push the bulbs in a bit then twist? Only a slight twist though it may just release the bulb |
Hahaha would help if i were not trying to change the wrong bulb in the first place |
| All times are GMT |
