Home > Off Topic > Japan moved 7 feet
Japan moved 7 feet
I read that due to the recent earthquake in Japan the whole landmass of Japan has moved 7 feet west - if this is so surely everyones Sat Nav in their cars will be Censored , tell me if I'm wrong. 2005 Zambezi TDV6 - Gone but not forgotten
Post #292895 Sat Mar 19 2011 8:35pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
your wrong
the sat nav provides your position relative to the earth using the wgs84 model not the other way about and not in relation to the position of japan, your position is from the satellites..and they havent moved
so effectively if you were in japan on a particular road...prior to the earthquake you would be registered in the right position..after the earthquake your position would be the same but the map under your position would have moved
Post #292897 Sat Mar 19 2011 8:39pm
I just knew I was being stupid! 2005 Zambezi TDV6 - Gone but not forgotten
Post #292903 Sat Mar 19 2011 8:42pm
ronniet101
dont be hard on yourself..its not being stupid, its a complex system with very complex maths behind it
did you know sat navs are very inaccurate in height, also it can be jammed, the timing can be adjusted to make everyones satnav apart from the militaries more inaccurate
Post #292904 Sat Mar 19 2011 8:46pm
DSL
Just coz Japan moved, doesn't mean we did! Don't get me started on plate tectonics but the oceanic crust between Japan and Chinese part of the Eurasian plate would have stretched a bit to take up the movement. Your satnav is safe but different GPS in Japan will show a difference. Whistle
Post #292907 Sat Mar 19 2011 8:49pm
Of course I knew that! Whistle 2005 Zambezi TDV6 - Gone but not forgotten
Post #292908 Sat Mar 19 2011 8:49pm
Dsl. I meant peoples sat nav in japan 2005 Zambezi TDV6 - Gone but not forgotten
Post #292909 Sat Mar 19 2011 8:51pm
DSL
Rolling Eyes Rolling Eyes Thought you were concerned peeps on the M25 might get lost! Whistle Whistle
ISTR once they disabled dithering on GPS then error on non-DGPS was 15m so they'll be fine. Mr. Green They might have more of an issue if they rebuild the roads in a different place. Whistle
Post #292911 Sat Mar 19 2011 8:54pm
paulo_martins
If it helps, i thought the same thing VA, it makes two stupid LOL
another idea, if japan is closer to the US now, will flights be cheaper!? Cool http://paulomartinsphotography.tumblr.com
Post #292917 Sat Mar 19 2011 9:24pm
DSL
As long as they don't want to charge more for UK to US as that distance is increasing. Whistle
Post #292920 Sat Mar 19 2011 9:29pm
Will it affect post codes or telephone dialling codes i wonder Question Laughing
Post #292928 Sat Mar 19 2011 9:53pm
Will sat tv dishes need to be repositioned? 2005 Zambezi TDV6 - Gone but not forgotten
Post #292929 Sat Mar 19 2011 9:55pm
DSL
You have more than one dish?? Shocked Shocked
Post #292932 Sat Mar 19 2011 10:01pm
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Hey I thought it was my job to be blonde !!!!! Smile
Post #292935 Sat Mar 19 2011 10:05pm
paulo_martins
it's your full-time.
im in it just for the part-time http://paulomartinsphotography.tumblr.com
Post #292944 Sat Mar 19 2011 10:40pm
