Home > Technical > Fault code U0402?
Ever since the pothole I have noticed the gear selection rather random, ie: dropping down quicker when not really needed, and rev pickup when accelerating with not as much actual momentum increase. I put it down to the 19" spate initially but now all the alloys are matched again it's still doing it. RRS gone
Post #290414 Sat Feb 26 2011 2:45pm
another thought
Would having a brand new tyre on the NSF be causing an issue?
The OSF is part worn but certainly not anywhere near half life (only done 4k in it since I got it)
Just thinking of possible suggestions when it goes in. RRS gone
Post #290639 Mon Feb 28 2011 5:01pm
Try swapping both your wheels around front to back, your rears will be more evenly worn and it might help eliminate the problem.
Post #290663 Mon Feb 28 2011 7:28pm
car gone into dealers today....
They are as bemused as I was... communication error from the transmission module
I've suggested swapping front and rears to him to see if that solves it... got the usual "we're unable to calibrate the car to 22" wheels" line...but I told them it's been fine up to the other day when I replaced the front alloy....
Fingers crossed for a solution anyway.. RRS gone
Post #292241 Mon Mar 14 2011 3:19pm
Where did you manage to get a new wheel from? just incase i should ever need one or i might just get one as a spare anyway.
Post #292244 Mon Mar 14 2011 4:00pm
Bespoke Autostyling Ltd
Unit 15 Galley Hill Ind Est.
Galley Hill
Waltham Abbey
Essex
EN9 2AG
08000 842782
07803 497754 RRS gone
Post #292245 Mon Mar 14 2011 4:02pm
Cheers Thumbs Up
Post #292249 Mon Mar 14 2011 4:28pm
Well, it turned out to be track rods so far out causing gearbox confusion and then fault codes. RRS gone
Post #292265 Mon Mar 14 2011 7:22pm
Endjin
Scotland
Was this also as a result of the pothole impact? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #292270 Mon Mar 14 2011 7:55pm
Must have been because I had the tracking done just 2 months ago.
The gearbox must really have been confused because the performance now is back up to nothing short of fantastic. Also, the mpg gas jumped to 26.4 mpg RRS gone
Post #292276 Mon Mar 14 2011 8:44pm
