![]() | Home > General > URGENT - AA concerned about towing |
for that short distance, using N should be fine. RRS gone
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
AFAIK should be fine in N, certainly done that to mine a couple of times. DO NOT let them use a spec lift and raise one set of wheels. Plus make AA dude a cup and check what your manual says. |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
All sorted - trying to steer without power steering is nigh on impossible. Hope I never experience a failure while on the move - totally understand why people are so angry when it happens to them. Must be terrifying. |
Happened to me on way up to Shap summit on the M6. Complete shut down of everything, engine, power steering, suspension dropped & about half a dozen other warnings. Luckily quiet & got to hard shoulder no problems. It's all part of the fun & frolics that is running LRs! |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
the AA have these things called skates that they put on all four wheels and this allows them to slide it across and up the back of there lorry with a winch
How was this sorted? According to my information, if there is electrical power, the RRS can be be towed (4-wheel towing), provided: 1. Ignition switch turned to "II"; 2. Gear selector lever in "N" position; 3. Transfer case is in "H", HIGH position; 4. Parking brake released. Caution: The vehicle may be towed for a maximum of 3 hours or 90 miles (150 km) at a maximum speed of 30 mph (50 km/h), these limits MUST NOT be exceeded. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
thanks Bobby - yep pretty much exactly that - 2 men from the AA pushing, me trying my hardest to steer! |
