![]() | Home > Maintenance & Modifications > Painting Brembo's |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
They scare the b'Jesus out of me.... Sorry... I'd not feel safe with 2.7 tonne of Land Rover perched on that slim jack... RRS gone Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Thats how i did mine on the sissor jack |
Why don't you have a go refurbing them yourself, its only about an hour a side, just make sure you get all the grit and grime off with a good brake cleaner and sand down where necessary mask all the componants you don't want spraying, prime then paint then new sticker job done. Ady |
| Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586
Found this company on line..... http://www.brake-caliper-painting.com/
| lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052
Jack off the axle then you will have enough height. Made that boo boo myself.
sorry to sound dim..
Big flat area of wishbone, from memory a round indent is there where you can locate lifting point of jack.
According to my jacking instructions (land rover) you arn't suppose to jack up on the diff |
Not something I have done but have seen done by proffessionals who work with Landrovers every day.
| airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248
where do u get the stickers ?
| Jmac Member Since: 17 Feb 2011 Location: South Posts: 125
eBay.. Search Brembo stickers. Not sure of the size though.. If anyone knows off the top of their head, pls post here.. Otherwise it's out with the tape measure! And we all know how inaccurate that can be J |
These are the ones i purchased 80mm
If you have the Brembo brakes you will need the 100mm transfers for the fronts
Anyone know anywhere that will paint them for you? Properly, baking them in oven or whatever they do, then reapply decals? |
