![]() | Home > Maintenance & Modifications > Jacks |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
I've just discovered my mini 2 tonne trolley jack doesn't have the reach required to lift the Sport.
Neither will do. You need a min 3 tonne jack and that air jack has been tried and tested and it doesn't work. There are other airjacks that do but are expensive. 2005 Zambezi TDV6 - Gone but not forgotten
Can I give one bit of advise - when lifting always put your spare/removed wheel under the RRS, next to jack just in case the jack gives way. Not only will this protect your car it might protect you. 2005 Zambezi TDV6 - Gone but not forgotten
| scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 |
i have one of these to lift my full fat, works well...
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440
6 tonne bottle jack usually works fine, compact and fairly cheap |
and highly unstable! 2005 Zambezi TDV6 - Gone but not forgotten
| lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052
Best to Jack off the axle as said above. Much less height required from the jack that way. Getting one with a higher lift to jack on the landrover jack points bringings its own problems with stability.
