Home > Technical > Brembo Brakes
johnmi
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
Brembo Brakes
How do you change the brake pads on a 07 sport s/c, do you have to unbolt the caliper? i have read somewhere that you just have to remove the pins, if so do they unscrew? and is there a sensor on each pad.
thanks in advance
john
Post #289813 Mon Feb 21 2011 9:08pm
shepp
search for bobby,
he has the documents under his documents Thumbs Up
Post #289907 Tue Feb 22 2011 7:33pm
johnmi
thanks shepp but thing have got worse i cant get the locking nuts off on one of the wheels it just keeps spinning as if it the key part of the nut has seperated from the part that screws on. any thoughts on that one?
john
Post #289962 Wed Feb 23 2011 9:51am
shepp
I was gust changing my nuts and locking nuts yesterday for shiny new ones. I noticed the locking wheel nuts do seem to be constructed in two parts. A base and a cap stuck togeter. Possibly for security.
The lower part of the locking nuts do have locator grooves. So I suspect you have not inserted the adaptor deep enough over the nut causing breaking the seal causing the head to rotate.
You. Should be able to locate the grooves in line and fully insert the locking nut adaptor. May need a slight tap with a soft mallet
Hope this helps.
Post #289976 Wed Feb 23 2011 11:26am
shepp
Just a quick search and found this for brake pad change
http://www.rrsport.co.uk/forum/topic8406.html
Post #289978 Wed Feb 23 2011 12:00pm
johnmi
thanks that is brilliant, being as i cant get the front wheel off i will do the rear ones tonight, booked the car in the garage for tomorrow. the guy there says it happens a lot and he has all the drills and bits to get it off, also ordered a new set off ebay for £40 as the adapter has rounded corners on it and i dont want problems if i get a flat tyre.
john
Post #290023 Wed Feb 23 2011 5:37pm
