![]() | Home > General > HOW DO I REMOVE DOOR HANDLES thx now sorted |
td6006 Member Since: 20 Feb 2010 Location: wales Posts: 45 ![]() ![]() |
DOES ANYONE KNOW HOW TO REMOVE THE DOOR HANDLES FOR ME TO REPLACE THEM WITH NEW PAINTED ONES, MINE ARE THE ONE PIECE ONES ON AN 05 MODEL, REGARDS TD6 |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Using search button first helps |
thx npinks, even though sensing a little sarcasam there.
Warren G Member Since: 09 Mar 2010 Location: Herts Posts: 98 ![]() |
The search on here is pretty naff...i struggle. |
its hitting the back button (after reading through some posts) that does me in once you have found a thread.....it dont work.....you have to start over again......arrrggggggggggggg |
right click and open thread in new windows, keeps the search results there whilst you check each thread out |
Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117 ![]() ![]() ![]() |
If you hit the refresh button then select the re-try it brings the previous search results page up. It will only do that on page 1 of your search results, once onto page 2 onwards of the search results the back button will work perfectly (on windows).
fanx lads |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402 ![]() ![]() ![]() |
Im going to do this as soon as the weather picks up, i wasnt aware that there are springs in the front doors?. I have complete 1 piece handles to replace and was advised of this procedure, is anything missing :-
HI CARLOS THE INSTRUCTIONS YOU HAVE LISTED ARE NOT QUITE RIGHT
Hi td6006
HI
Hi td6006
HI CARLOS SORRY BEEN AWAY, YOU WILL NEED A T25 BIT BUT THE ONLY THING THAT WIL FIT IS AN ACTUAL T25 SCREWDRIVER, IT IS THE ONLY THING SMALL ENOUGH TO GO THROUGH THE HOLE , TIP MAKE SURE YOU ONLY UNDO THE SCREW A COUPLE OF TURNS IF IT FALLS OUT YOU WILL NOT GET IT BACK IN.HOPE THIS HELPS IF YOU HAVE NOT ALREADY DONE JOB |
