| RRSPORT.CO.UK | ||
|  | Home > Technical > range rover sport battery |
| simonw007 Member Since: 01 Dec 2010 Location: London Posts: 19      | I believe Diesel engines require 950A, petrol only 850A.
|  Sat Feb 12 2011 9:03pm |
| dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212      |
 mines diesel i guess someones put the wrong battery on it it struddled to start the other day thought it was me messing about with lights without the engine running i was quoted £140 by landrover any one know off anybody cheaper for a battery   | ||
|  Sat Feb 12 2011 9:25pm |
| td6006 Member Since: 20 Feb 2010 Location: wales Posts: 45    |
 I BOUGHT A NEW BATTERY FOR MINE LAST SUMMER NOW AND AFTER CHECKING WITH DEALER PRICE WAS ABOUT 120 WITH ONLY 12 MONTHS WARRANTY ,I STARTED CHECKING AROUND FOR PRICES, AND FOUND THESE GUYS
|  Sat Feb 12 2011 11:39pm |
 hi thanks even cheaper now £74.65 but it doesnt say what amps it is does it say on your battery cheers   | ||
|  Sun Feb 13 2011 4:45pm |
 HI THERE DAZZERBOY CHECKED BATTERY FOR HERES INFO
|  Sun Feb 13 2011 8:59pm |
 ok thanks will purchase one tommorow   | ||
|  Sun Feb 13 2011 9:24pm |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402      | So its fine to fit the higher 950A battery to a Supercharged ?
|  Sun Feb 13 2011 9:59pm |
| MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261      | Yes, I put the 950A on my 4.4 V8, it's the TDV8 battery I think. Spins her over a treat   | ||
|  Mon Feb 14 2011 1:24pm |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402      | I measured the dimensions of my battery and found that its not as long as the Varta ones for example. Mine is 310mm whereas the Varta are 345mm. Anyone know if the longer battery will still fit into the tray, save me pulling the cover etc again? | ||
|  Mon Feb 14 2011 2:55pm |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402      | Simonw007
|  Sat Feb 19 2011 6:38pm |
| simonw007 Member Since: 01 Dec 2010 Location: London Posts: 19      | Hey Carlos,
|  Sat Feb 19 2011 9:53pm |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402      | Hi Simon
|  Sat Feb 19 2011 10:25pm |
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402      | Forgot to ask, when the battery is changed on the RRS do any memory functions etc need to be reset or is it all ok ?
|  Sat Feb 19 2011 11:11pm |
| rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173      | Always remove the earth first... and on re-fit always connect the positive first.. that way if you should happen to touch your spanner on the body while removing/re-fitting it won't make BIG sparks   | ||
|  Sun Feb 20 2011 12:02am |
| Posting Rules
