![]() | Home > General > Number plate size |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Is it the standard one's your after?
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 ![]() ![]() ![]() |
The Rear is 536x153mm The front Standard. |
jamiequ1 Member Since: 23 Jan 2011 Location: london Posts: 58 ![]() |
So what does the car cone with from new , and to people change them because they don't like the look of the shaped one? |
They come with standard. |
But there are two different styles for the rear - some are shaped like Focus and Rover75's like this
Royle Member Since: 24 Nov 2010 Location: Perth Posts: 211 ![]() ![]() |
On mine I had the "wing" effect plate (not sure the accurate name is) I got mine from Demon Plates. Once you have your reg in go to plate size, model specific and choose. You can just use the standard one obviously but I think that the shaped one finishes it off.
Thanks for that Tim , it does look as if there is something missing when a standard plate is put on the rear, look like it has been put on as an after thought. |
Thanks for that Royal , just the job ![]() |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
Jamie it came with the shaped plate (like Rover 75) but I swapped for standard as I prefer it. Bought from No 1 showplates website. |
Mine came with the standard oversized rear plate and I changed for the wing style |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 ![]() ![]() |
just to confuse you even more,i have just ordered a "wing" type plate but it looks smaller than the one's in the photo's.when i fit it i will try to post a photo of it,due for collection thursday. |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 478 ![]() ![]() |
I am happy to be wrong but all the listings show the following as the rear plate size option??
I have the standard size on mine,it’s the only size my supplier does.plus I prefer it as the bigger ones show too much yellow.
Jeez, that number plate doesn’t half get around......
