Home > Maintenance & Modifications > cornering lights
pex18
Italy 2007 Range Rover Sport TDV8 HSE Lugano Teal
cornering lights
Hi to all members!
I've a little question: on my 2007 RRS TDV8 the cornering lights just start if I use the side repeters, but on a my friend's 2007 RRS TDV6 with dynamic response the cornering lights work always when he turns the stering and under 45 km/h.
Anyone knows how to activate this?
Thanks a lot for your time and excuse me for my bad English.
Post #288501 Wed Feb 09 2011 9:31am
carlos50
Mine is a 2005 S/C with dynamic response and cornering lights, they only activate at slow speed and with the indicator on. Definitely slower than 45 kph, more like 10 kph (mph ofcourse here in the UK)
Post #288803 Fri Feb 11 2011 8:01pm
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
with the last version the cornering light goes without the indicator...
ciao
Post #288815 Fri Feb 11 2011 9:48pm
flydive
I do not think it has anything to do with dynamic response, probably more with adaptive lights, but not sure.
My old TDV6 did not have DR but had adaptive lights, the cornering lights behaved like my present TDV8 with DR and adaptive, come on with indicator or turning the steering wheel(and for sure up to speeds faster than 10 kph) '08 RRS TDV8
Post #288816 Fri Feb 11 2011 9:57pm
muddywheels
Milk Float Man
I have a MY10 and cornering lights only come on at slow speed when indicating Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #288835 Fri Feb 11 2011 11:54pm
naylor04
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
On MY55 I only have 1 cornering bulb (Drivers side ) , the passenger side looks like it has a silver ball in it's place where the bulb should be ? Does anyone have any answers to this please , I've searched everywhere Confused
Post #480098 Tue Nov 17 2015 9:56am
Tim in Scotland
Naylor both lamps should look the same, I suspect that your nearside lamp may have blown. I ts possible to replace these with LEDs now so might be worth looking into replacing both lamps at the same time.
In all the cars I have had with Adaptive headlights the "directional" side light has always come on when indicating and the speed has been below about 25mph AND when the headlights are on dipped beam (like in a multi storey carpark) when the doing above or just turning the wheel more than a set amount at low speed. I was always surprised how many passengers used to comment at night that they could see an additional light coming on when driving the local very twisty back roads where the corners can only be taken at very slow speeds. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #480099 Tue Nov 17 2015 10:03am
naylor04
Hiya Tim , thanks for getting back to my post , I've had a look at the passenger side headlamp and there isn't a bulb in there , not even any wiring . Looking at the headlight from the front all I can see is a chrome dome where the bulb should be . ?
It looks like i only have cornering lights on the drivers side ?
Post #480102 Tue Nov 17 2015 10:10am
naylor04
Here is a pic , not great put you can see what I mean
Post #480103 Tue Nov 17 2015 10:20am
Looks like someone has replaced one of the headlights with the cheapest unit they could find. Hence the lack of a static bending beam in that unit. 2012 SDV6 - it's missing a couple of cylinders
Post #480107 Tue Nov 17 2015 10:31am
myfirstrrs
I have a MY10 and cornering lights come on at low speeds but do not require the indicator to be on. Could it be different for a TDV8?
Post #480108 Tue Nov 17 2015 10:32am
naylor04
You know what , I was starting to think that myself to be honest , strange thing is it still passed the MOT ?
Post #480109 Tue Nov 17 2015 10:35am
Lost for Words
No, they do all do that AFAIK. There are two separate "functions"; the "cornering [lamp]" - with the indicators, and the "static bending" - with the steering. Thumbs Up Visiting from DISCO3.CO.UK
Post #480113 Tue Nov 17 2015 10:59am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Are you sure it's not a silver bulb been put in I replaced all my Orange bulbs with the chrome ones, Maybe they put one in the direction position by mistake. I would take the headlight out and investigate the rear itisme
Post #480118 Tue Nov 17 2015 12:01pm
TheWojtek
2005 SC here, my cornering lights work up to around 40-45 kmh without indicators and always with indicators. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #480120 Tue Nov 17 2015 12:20pm
