![]() | Home > My Range Rover Sport > Stornaway Overfinch TDV8 |
m6totdv8 Member Since: 06 Dec 2010 Location: West Mids Posts: 51 ![]() ![]() ![]() |
Hi all
That is very nice |
Lovely example |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
Stunning sir! |
Cheer guys......was lurking on here for a good few months before I picked this one.
I'd say thats normal, cane any diesel from a standing start and you will get some smoke and yours is no different than any other, Take note next time you are following other diesels. |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Try adding two stroke oil to the diesel that will stop the smoking.. |
No it doesn't Ady |
Yes it does - Due to the pollution control measures of the EC diesel-oil is nearly sulphur free and contains up to 5% of bio-diesel. Sulphur has the property to grease the high pressure injection pump and the injectors. Without sulphur, the reduced greasing property of the new diesel has already shown negativ impacts on the long-term stability of the injectors and the high pressure pump. The pump manufacturers have tried to react by lining the moving parts of the pumps with teflon or other suitable material. However, the long term stability is still not achieved as with the old (sulphor contained) diesel.
So how many motor saws and lawn mowers do you know that run off diesel then? I thought they all run of petrol |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
Does anyone else add 300ml of 2 stroke oil to their diesel tanks? sounds pretty beneficial all in all.... |
I do
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
Let me get this straight, you guys are adding 2 stroke to your TDV8 RRS |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
i think it should also be stated what 2T you can add ...... if you believe the hype |
