Home > General > Auto windows not working
big pimp
Hi guys,
I was having a problem today with my auto window on the drivers side.
It will go down automatically with one touch, but will not g back up with one touch.
I checked the fuses, removed them and replaced them, and nit both the driver and passenger windows are behaving the same - will go down by themselves but not back up
Does anyone have any ideas?
Thanks, MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #288331 Mon Feb 07 2011 9:23pm
muddywheels
Milk Float Man
I had this too - dealer told me you have to reset them as below Thumbs Up
Quote:
Resetting one touch operation
If the battery is disconnected, becomes discharged or the power supply is interrupted, the one touch up window operation is disabled until the window position is reset.
To reset the window position:
1. Close the window fully
2. Release the switch, then pull up and hold the switch for one second.
3. Repeat the procedure on each window.
 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #288333 Mon Feb 07 2011 9:32pm
Sizzle TDV8
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Big Pimp,
IIRC you need to re-programme the auto functions again.
This is done by simply starting the vehicle, push and hold the open window button until it fully opens, then pull and hold the close window button until it fully closes. Voila, the auto function for that window should be re-instated. Then do the same for the other.
Hope this helps. 2007 RRS TDV8 Stornaway Grey with lots of smiles..
2007 Audi A4 2.0T Cabriolet
Missing - 2008 Suzuki GSX-R 750
Post #288334 Mon Feb 07 2011 9:35pm
Sizzle TDV8
Or try muddy wheels tip who just beat me to it, lol Thumbs Up 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #288335 Mon Feb 07 2011 9:37pm
big pimp
Sizzle TDV8 wrote:
Big Pimp,
Hope this helps.
Tried this method mate, and it didn't work.
Will try muddy's recommendation now though.
Thanks again guys - really appreciate your help! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #288342 Mon Feb 07 2011 10:00pm
Sizzle TDV8
Ooops just seen yours is a 2010 (Dont know if that would make a difference but its the excuse I'm gonna use, Rolling with laughter )...... Lets hope muddywheels way works.
Let us know in case someone else has this problem in the future. 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #288465 Tue Feb 08 2011 9:57pm
big pimp
Just to confirm, the method recommended by Muddywheels worked on my 2010 perfectly!
Thanks again guys! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #288500 Wed Feb 09 2011 9:20am
Phil B
Love this forum - a 6 year old thread solved my problem. Thanks guys......
Post #516872 Sun Feb 05 2017 9:30pm
Brit Plumber
I’m pretty sure my rear windows used to have auto close off the drivers controls but now only the fronts go up with one press. Can anyone confirm that they should close on one press/lift of the switch? Car is 2012 AB. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #571525 Sat Dec 22 2018 4:24pm
TubaPlayer
The rear ones on my 2013 are one touch, I had to reset them as this post after i'd had the battery off. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #571533 Sat Dec 22 2018 5:40pm
Brit Plumber
Censored , that means something’s wrong. I’ve tried the reset on both but still nothing. 2019 5.0 SC SVA (Current)
Post #571541 Sat Dec 22 2018 6:41pm
XIII
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I’ve got a 2012 SDV6 and muddywheels reset works on all my windows which were njot one-touch when I got mine but using the reset method below have worked ever since I rest Thumbs Up
Thanks again muddywheels Bow down
Post #571552 Sat Dec 22 2018 11:16pm
garrycol
Australia
Can someone confirm that one touch rear windows are not available on an 07MY poverty pack TDV6 - the one touch works fine on the fronts and manual on the rears but one touch has never worked on the rears.
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #571566 Sun Dec 23 2018 3:20am
Mrbrizight
United States
This is awesome. Just bought a 2010 and was scratching my head about the auto up not working. Thx for the advice on the reset!
Post #610127 Wed Feb 17 2021 9:06am
grimreaper
one touch windows
Been bugging me for a while now 2010 RRS Autobiography face lift 3.0 Muddywheels trick worked great fixed the rear N/S window not going up on keyfob button thank you.
Post #614721 Sun Jun 13 2021 12:25pm
