![]() | Home > General > Cut out while driving then starts but rough no acceleration |
| timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235
My 2.7 TDC6 whilst driving home last week decided to die, when i pulled over although it would startt was idling like there was a deisel blockage of some sort, however took into the dealer and they say no faults are registering but are going to check Cam Sensor does anybody have any ides? |
EGR Valve sticking? common fault
LR left a message that they can't find the problem so are removing more to check camshaft sensor fully is this in line with checking EGR?
| GTSteve Member Since: 20 Dec 2010 Location: northamptonshire Posts: 38
Had the same fault on my Discovery 3 TDV6, Faultmate confirmed it was the EGR valves, so I bought some blanking plates had them fitted the car was right as rain after that, and fitting blanking plates was a lot cheaper than the EGR's would have cost. BLACK RRS HST 3.6 MY08 |
| 1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530
Blanks are only possible on a pre 2007 model year! |
Hi, had a call from Guy Salmon today after 3 days looking at my RRS to tell me the engine has gone.
What |
I wish, no now say knackered and need a new engine? |
Not the first time I have heard this, what has actually gone wrong with the engine? |
At this moment they cant say just say I must have drove without oil, umm don't think so
Anyone any ides as the car starts up as it did when I dropped it in but runs rough with no acceleration
I'd get a second opinion
Just thinking that but where do you go? Are they all going to stick together or do I use a specialist
Sounds like your timing has slipped ask around try to find an independent LR specialists ask him to give it the once over or pick his brains tell him the symptons and ask your dealer to be a bit more specific of the failure. Good luck
| All times are GMT |
