![]() | Home > Maintenance & Modifications > Mod to make rear map / reading lights come on? |
| Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117
Thanks to Simons and Alans great work I just completed this using their fantastic guides. Just a few bits that you could try differently if you undertake this yourself....All at your own risk of course ( I take no liability for you completing this mod).
| big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548
Weather permitting I'm hopefully going to do this mod tomorrow.
| zb Member Since: 31 Dec 2010 Location: CI Posts: 72
will the rear map lights now come on if either rear door is open, or any door? |
Not by themselves I don't think. I don't think
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421
Rear reading lights work with all the courtesy lights. Whenever you open any door they come on with the othe lights. By using the diodes it also means that they will continue to function as reading lights without making all the courtesy lights come on as well |
| Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539
And I will second that! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!! Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill Ex - Audi A4 Cab 3.0TDi Quattro Ex - Freelander2 SE TD4 Ex - CRV Auto |
I just dome this today and it took all of an hour to get it wired, soldered and diode fitted, and everything heat shrunk to keep it nice and safe and secure..... Delighted with it - such a relatively easy mod, but it begs the question as to why LR didn't just do it in the first place.
| flydive Member Since: 16 May 2007 Location: South Posts: 1213
Then we wouldn't have anything to fill our winter days I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Ross (big pimp) sorry I haven't got back to you sooner, only just got my laptop back. Take it you found the drainage tubes then??
| carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402
I want to have this feature on my RRS but am not confident enough to try it, how hard a job is it and can something go wrong etc?
Very easy |
Did you have any experience with wiring, soldering etc before doing this work ? |
Hi Carlos
This is how I did it, the "dirty" way Used butt connectors for the diodes and self stripping connector to connect to the boot light. No soldering in my case Very easy if you follow Simon's instructions and Sizzle's tips(the one re. switching the clips) '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
| All times are GMT |
