Home > General > Chipped TDV6 - Your impressions, is it worth it
Firebird
Australia
Hi guys,
Just have a couple of questions......
Understand the increase is not massive but provides similar spec's to TDV8.
With the extra power, obviously the engine does not need to work as hard so have you seen and improvement in MPG.
Also where do you sit with regard to warranty.
Post #286622 Sun Jan 23 2011 12:28am
Worth it? Yes most defiantly, same oomph as a TDV8? No unfOrtunatly not but still much more responsive than the standard map.
Mpg, with a k and n air filter I was returning a better mpg of 28 post bas map. RRS gone
Post #286795 Mon Jan 24 2011 10:03pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
Depends - if you're chipping a 3.0 ltr you'll get more oomph than a TDV8 Thumbs Up 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #286810 Tue Jan 25 2011 1:15am
