| RRSPORT.CO.UK | ||
|  | Home > General > Side steps + wife = not happy! Warrenty? |
| BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816      | Not sure if covered under a warranty but I know there have been other threads on people loosing the trim in the snow I think and the answers on the threads have been that the whole step needs replacing. You can't just buy the trim apparently   | ||
|  Sun Jan 23 2011 7:25pm |
| L888DER Member Since: 29 Dec 2010 Location: Essex Posts: 56      | That is a joke. £750 for a new pair! You can live in your car but you cant race your house
|  Sun Jan 23 2011 7:57pm |
| Jonas & Jonas Member Since: 27 Oct 2010 Location: Harrogate Posts: 161      | I completely sympathise with you on this. Christmas day I was heading North to Newcastle and the silver trim from my drivers-side step came off and hit the car behind, I felt a real tosser explaining to the Audi TT driver behind why there was a gash on his bonnet. Very long story short I took my sport to Ripon land Rover (as my RRS was/is still in warranty) and explained the situation they told me that they would have to replace the whole side step and that this could not be done under warranty as they couldn't prove whether or not my steps were fitted post factory...  | ||
|  Sun Jan 23 2011 9:18pm |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | they are riveted on and its the rear of the rivets that break or usually corrode from the side step its self... pretty   | ||
|  Sun Jan 23 2011 9:26pm |
| baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273      | both mine fell off on the driveway when we had the snow they are easy to put back on just raise the car to off road height push it back on climb under the car and you can see a recess in the step its self drill a few pilot holes through the back with a small metal brill bit and then screw through the holes with a screw big enough to go through recess and into metal trim make sure the screw is long enough to go through both and not to long it comes out of the front of the trim i was able to do this as iam very good at diy a lot cheaper than replacing the 2 steps hope this helps   | ||
|  Sun Jan 23 2011 9:27pm |
| SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 541      | Loose the wife, loose the weight and loose the side steps all together.  | ||
|  Sun Jan 23 2011 10:31pm |
| L888DER Member Since: 29 Dec 2010 Location: Essex Posts: 56      | Just taken the RR to the local car workshop and the guys have done a sterling job. I owe the wife an appology because i asked the garage to check the other side and when they checked that fell off too. The drilled out the holes bigger and used some large self tappers. apparnently there is "no way they are going anywhere" V happy. I also had the rear badge changed to black so they all match. 1.5 hours labour at a cost of £82.73 so vs the RR cost of £782 im very happy indeed......... You can live in your car but you cant race your house
|  Tue Jan 25 2011 2:46pm |
| Posting Rules
 off. Any help please. And before you say it, wife's 8.5 stone
 2005 RRS HSE 2.7 TDV6
