![]() | Home > Technical > Just broke down... engine system fault |
| disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147
You may have sediment in the fuel system if you're continuously running it low (or is that just a problem with Australian fuel over here?).
| NickM Member Since: 15 Feb 2008 Location: London Posts: 2995
Don't think it's the lack of fuel have had a couple of occasions in 3 years where I have driven in on 0 miles to get to a petrol station... |
Sounds like either a blocked fuel filter or sticking RGR valves. 2005 Zambezi TDV6 - Gone but not forgotten
| foobar Member Since: 19 Aug 2010 Location: Scotland Posts: 35
well the fuel filter was replaced less than 2000 miles ago and it cured theproblem back then, surely that wouldnt need replacing already? Presume you meant EGR valve? Can they be "unstuck" |
yes egr and they can stick and do stick. 2005 Zambezi TDV6 - Gone but not forgotten
So can they be unstuck or do I have to replace? Thanks |
As easy to replace as to clean - better to replace. 2005 Zambezi TDV6 - Gone but not forgotten
| DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045
Just has ESF again (about 8 now) on my d3, all at modest speed but putting in a bit of throttle to get out & round stuff on Mway or on hills. Changed air filter, fuel filter, intercooler, MAF sensor, EGRs new(ish) but blanked. Thinking it's turbo related but turbo is only 9 months old. Having her plugged in tomorrow to try and see what else to change. Getting mightily |
I'll have someone to give me a hand looking into it tomorrow so we'll see what happens. |
Most replaced due to maintenance or offroading use/abuse so you should be OK. Had it plugged in to an Autologic reader and it has come up with TURBO OVERBOOST type fault, again, pointing to either turbo actuator linkage needing fixed (again) or a new turbo (again). Would also explain my 20% drop in mpg, chart shows clearly when the problem occurred. |
Well luckily it looks like my issue was fuel related. Got some power in the battery, bled off a very small amount of air and kept cranking her for 30 seconds and away she went. WIN! |
| timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235
Help, on my way home went to over take a line of lorries and buggar started to slow down, no warning lights, 80 miles of fuel still showing and came to a stop eventually when a lorry let me in to become stuck on the inside lane of a dangerous dual carraigeway, AA eventually came twohours later and my eyes sore from cringing now recovered to garage and awaiting outcome, plugged in to computer breifly to ahow no faults, any ideas, thanks |
Welcome to CMLRTTCM (Club My Land Rover Tried To Kill Me)!! |
Hi, YES, in the two hours sat there attampts 200+ but was a good excuse for alcohol |
