Home > Technical > 2008 TDV6 Front Brake Upgrade to 380mm
SR71
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
I've done a search and not quite come across the answer I was looking for...
I also know there are some uber expensive brake upgrade kits for the RRS but...
Does anyone know if the 380mm discs are a bolt on upgrade option for TDV6 owners? Perhaps with a caliper spacer to move the OEM calipers out a bit?
I've just come back from a Swiss trip, four up with a boot full of gear and 2 top boxes and the only thing I'd say is that I'd prefer a little less braking effort for the effect generated.
I'm wondering if simply fitting a bigger disc will improve things somewhat... 00 Audi B5 S4 MRC550'ed
08 RRS TDV6 HSE
03 Kawasaki ZX12R 1287cc
04 Audi 8P A3 2.0 TDi S-line
Post #286125 Mon Jan 17 2011 12:11pm
Adam RRS
I fitted the TDV8/Supercharged calipers and discs to mine
Massive improvement WINNER - 2009 Best in Class Range Rover Sport Award
MY14 Corris Grey RRS HSE SDV6
Post #286127 Mon Jan 17 2011 12:37pm
SR71
Thanks Adam.
The thread about your experience got a bit silly when you did it back in 09.
PM me how it all worked out in the end if you don't mind. Did you get the bolt issue sorted?
I'd agree that if you're howling down mountain passes on the continent (which can go on for miles) in the car fully loaded you will easily appreciate that the brakes could be better.
The fact that its a diesel doesn't make any difference to the fact its still 3 ton that needs stopping.
Mr. Green
Cheers. 00 Audi B5 S4 MRC550'ed
08 RRS TDV6 HSE
Post #286129 Mon Jan 17 2011 12:49pm
Adam RRS
Exactly... 100mph in a TDV6 or 100mph in a TDV8 or Supercharged... you still wanna stop!! Not sure why Land Rover divided the two. Like you say, car still weighs the same...
Forget my post in 09, me being silly, I bought the wrong calipers! They were sold to me as RRS upgrade when infact, they were for the FFRR.
If you do the upgrade (with the correct parts!) its honestly straight forward. WINNER - 2009 Best in Class Range Rover Sport Award
Post #286133 Mon Jan 17 2011 12:55pm
ANL53
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
2010 TDV6 Front Brake Upgrade
Is it possible to upgrade the TDV6 brakes to Supercharged front brakes on 2010MY RRS?
Do another parts needed to be change different form calipers and disks?
Help please.
Thx. '10 RRS TDV6 Startech, Overfinch, Strut
Post #287784 Wed Feb 02 2011 7:55pm
