![]() | Home > Technical > No power and no acceleration (solved) |
| tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244
37k on mine |
Cheers Ady |
| 1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530
23,000 miles on mine and just had to replace EGR valve on one side, can't blank due to engine light as it is a 2007 car |
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421
40,000 on mine and one of the valves had to be replaced last week... |
| SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 541
110 000 km on mine. SW
I fitted the blanking kit from Bell Autos today, using their excellent instructions. The pipes into the butterfly valve were pretty coked up, and I can see that they wouldnt help airflow into the engine either by their positioning, or the amount of rubbish they were sending back in.
| PHYLRRS Member Since: 18 Sep 2009 Location: Brabant Posts: 18
106.000 km.
| L888DER Member Since: 29 Dec 2010 Location: Essex Posts: 56
What are these valves, what do they do and what should I look out for? Can it harm anything? Thanks. You can live in your car but you cant race your house
The EGR Exhaust Gas Recirculation Valve, takes the exhaust gas back into the engine to be burnt, thereby keeping emissions down, only required to meet stupid Euro emission standards. The problem is they coke up and stick or the roller bearings inside break up. Failure rates and mileages vary, nothing you can do until the orange engine light comes on, then blank if it is a pre 2007 car or replace EGR valve in post 2007 cars. |
| MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156
if the EGR valves are failed does it show a light on the dash?
EGR blanking kit fitted.
| All times are GMT |
2005 RRS HSE 2.7 TDV6
