| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Newbie With intermittent fault with Cruise Control |
| ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163    | Sounds like the clock spring, go to the Disco3 site and do a search for the full info. | ||
|  Wed Oct 13 2010 9:07pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Also your S/C has adaptive cruise - you may have a problem in the sensor head in the lower front intake. Unfortunately if the sensor doesn't work or had cut out (like it does when we get about 3 flakes of snow) you don't revert to traditional style cruise. Check the plastic cover of the detector head isn't cracked and letting water into the unit 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Thu Oct 14 2010 8:56am |
| barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187      | Thanks for that Tim, Had a look at the cover all seems Okay, There is a round hole to the left side ( 1/2 inch) is it supposed to have a rubber bung ?? | ||
|  Thu Oct 14 2010 9:34am |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Unfortunately my new car doesn't have the ACC like the last one so I cannot go out and have a look, but somebody else with the system should be able to help - from memory there were not any holes except at the back of the unit on the TDv8 Sport I had. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Thu Oct 14 2010 11:53am |
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421    | Hi Barry
|  Thu Jan 06 2011 12:52pm |
| barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187      | Hi  Simon,
|  Thu Jan 06 2011 1:20pm |
| barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187      | Hi Smon Sorry to be a pest but do you know where the ECU is situated on the car,
|  Mon Jan 10 2011 4:20pm |
|  Mon Jan 10 2011 4:42pm |
| barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187      | Thanks again Simonjavascript:emoticon(' | ||
|  Mon Jan 10 2011 6:25pm |
| Posting Rules
