Home > Technical > Fuel consumption 3 litre V6 diesel (very poor new vehicle)
Page 2 of 7 <1234567>
gordon kerr
England 2007 Range Rover Sport TDV6 SE Java Black
Run a 2.7 v6 myself so cannot comment specifically on the actual consumption figures you are reporting but a couple of points:
1. My fuel consumption computer doesn't even know what day of the week it is, hopelessly inaccurate, try calculating it for yourself and see if it is any different (that said mine is actually over optimistic so this might make things worse rather than better).
2. Cold weather will make things worse if you are calculating yourself because some of the fuel will be used up by the fuel burning heater - I guess if you let the computer do the calculation they might have a clever way of allowing for this. I have certainly seen an increase in fuel consumption over the last few weeks.
Gordon Gordon Kerr
Bedford, UK
2007 Java Black RR Sport TDv6
1980 Brooklands Green Triumph TR7
Post #284808 Wed Jan 05 2011 10:10am
Gary
You are correct using more fuel during warm up, but I am talking about once the Engine has reached normal opperating tempreture, I personally have noticed better performance and consumption on all of my vehicles, 2.7 Diesel, 3.9 V8 petrol and 3.2 V6 Petrol over a 50 mile round trip daily, this is how the intercooler's work by sqeezing cooler air into the cylinders?
Post #284812 Wed Jan 05 2011 10:27am
Tboner
Do not agree esp on Turbo engines there are optimal temp ranges when it is a hot day for example a downpour will help turbo engines even more than normally aspirated motors you can even run more boost if required when the temps are optimal but not when to cold or to hot. Petrol engines will always be better when they run at the cooler end of the range but will give optimal power at only a short area of temp and this is normally a little warmer than a TD engine the lambda sensors and maf sensors will adjust the timing based on ambient and moisture variables and then adjust fuel ratio's to suit. 2014 5.0SC AB
Gone 5.0 SC
Post #284819 Wed Jan 05 2011 10:51am
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
The A6 that I had was quoted as 46 mpg Extra urban but in real life would do no more than 32 mpg. When I complained about it being advertised as that I was told I was "stupid and naive" to expect it to do the published figures!! I take it as read that most cars will only ever achieve the "combined" figure and that usually works out about right for a long run.
Manufacturers can publish what they like in the brochures as long as it meets the EU regulations for achieving the figures. They work them out as follows:-
The urban economy is measured using the test cycle known as ECE-15, introduced by the EEC Directive 90/C81/01 in 1999. It simulates a 4,052 m (2.518 mile) urban trip at an average speed of 18.7 km/h (11.6 mph) and at a maximum speed of 50 km/h (31 mph). The extra-urban cycle or EUDC lasts 400 seconds (6 minutes 40 seconds) at an average speed 62.6 km/h (39 mph) and a top speed of 120 km/h (74.6 mph).
You tell me how that represents a real life driving situation??
Also heard stories of manufacturers allegedly fitting switches to make the engines run leaner when it comes to putting them through the above test cycle. Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #284921 Wed Jan 05 2011 10:48pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Taking the urban and combined official figures I do actually achieve these in my TDV8 and that's with me driving it pretty hard all the time. If I drive it carefully I can easily exceed them. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #284929 Wed Jan 05 2011 11:37pm
SR71
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
I recently did 1600 miles to Aviemore from South Wales with a blast around the Highlands and the combined average for the trip was over 30mpg...can't actually remember if it was 31mpg or 33mpg.
I must have cruised for 1200 of those miles at an indicated 80 using cruise, and 600 miles were with only me in the car and a few snowboards.
I was absolutely staggered.
Of course, I'm not sure if the actual trip computer is spitting out optimistic figures as I didn't work our total mileage and divide by actual consumption.
I'm well pleased with my vehicle in that respect as the baby 2.7 RRS in the line up. 00 Audi B5 S4 MRC550'ed
08 RRS TDV6 HSE
03 Kawasaki ZX12R 1287cc
04 Audi 8P A3 2.0 TDi S-line
Post #285072 Thu Jan 06 2011 10:00pm
dric0327
24000 miles done so far in 11 months and I have been staggered at the MPG I am getting. Averaging over 30mpg regularly and yesterday travelling back from Newbury to Nottingham I got 34mpg. Have verified my figures from the computer against the actual fill ups divided by miles and although less are within 5% .
So far so good. 2016 MY16.5 HSE, 21" Rims, Waitamo Grey, Cirrus Leather, Extended Leather, Meridian sound
i ain't no dizzy rascal
Post #285081 Fri Jan 07 2011 12:57am
BLH
I spoke to Land rover regarding this fuel consumption issue
and amazingly they have fuel specs for the vehicle when used over a 12 month period.
and for now month 'Jan' the V6 Diesel is stated as able to achieve an Average 27mpg
They state this is because of all the engine pre-heaters and other heating accessories that are being used.
(heated screens etc)
not exactly sure what figures there quote in the summer months when the air-con is whizzing its heart out.
Shame this nice 'fuel average chart' chart isn't printed within the brochure's
Post #285121 Fri Jan 07 2011 1:03pm
robbie1
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
hi iv had my 2.7 re maped and a k&n filter fited and the egr valves removed i then filled it up to the brim ran it around for week then filed it up again and it worked out that i was getting 27mpg and thats not motorway milesthat around the doors before i had the bits done i was getting 23mpg rob telford
Post #285244 Sat Jan 08 2011 6:25pm
muddywheels
Milk Float Man
I used to get close to manufacturers figures on both my last FL2's and my FL1 (34-36 mpg), but only getting 25-27 mpg on my RRS 3.0 Crying or Very sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #285250 Sat Jan 08 2011 6:42pm
Just out of intrest, who remapped your car Question
Ady
Post #285264 Sat Jan 08 2011 9:08pm
robbie1
hi it was dynachip who done my remap you can google them i paid £225 for the remap should not be much more than that for yours cheers rob rob telford
Post #285350 Sun Jan 09 2011 6:58pm
Melbop
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Hi all
I've read all of the above with interest.
Don't all shoot me down ,but
Has gears,revs and length of time in between gear changes got anything to do with fuel consumption?
In theory I assume that all tdv6 3.0 ecu's tell the gears at which point to change up or down?
Does this happen in practise with every car ?
Could the guys with low fuel consumption report the gear/rev change point to guys with high fuel consumption.
Or am I completely off track?
I Bow down To those who know.
Melbop
Post #285382 Sun Jan 09 2011 9:58pm
Cheers, Thumbs Up
Ady
Post #285386 Sun Jan 09 2011 10:12pm
8 CDC
Scotland 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Here's an idea.....all those worried about your MPG, switch your read out to the clock. Not being sarcastic or anything, but if you are worried about a 2 or 3 mpg difference per tank of fuel.....you have surely got the wrong car. My mate drove mine back from Ayr to my house....a 30 mile journey and averaged 31.5. I jump in & within 5 miles its down to mid 20's?? Am I worried - no. Am I concerned there is something wrong - no. As far as I can work out, a 3/4 miles per gallon difference per tank is the price of a packet of cigs per week or a bottle of wine. When you are all out at a night out....your having a great night...do you walk away from having one last bottle of beer for 4 quid due to the cost or do you participate to continue the laughs for the last half hour.?
Ready for being slaughtered, but come on...let's be realistic. Mid teens there is more than likely a problem, low twenties...you are enjoying your wheels, high twenties....you are to be admired.
CDC Everybody is clinging on to their sanity….Some just hide it better than others….
Post #285396 Sun Jan 09 2011 11:43pm
