Home > Maintenance & Modifications > correct tyre presures please
ptwroofing
changed to 22" wheels/tyres could some one give me the correct presure for the fronts and the rears as not sure and am a new sport owner thanks paul
Post #285160 Fri Jan 07 2011 8:53pm
td6006
2005 Range Rover Sport TDV6 HSE Zambezi Silver
tyre pressures
HI I run my 22s on the same tyre pressure as recommended by Land rover for 20s which you can find on the label on inside of drivers door jam, hope this helps regards td6 Thumbs Up
Post #285161 Fri Jan 07 2011 9:13pm
ptwroofing
thank u Thumbs Up paul
Post #285165 Fri Jan 07 2011 9:49pm
ptwroofing
Post #285166 Fri Jan 07 2011 9:50pm
ptwroofing
Post #285167 Fri Jan 07 2011 9:50pm
8 CDC
Scotland 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Re: tyre pressures
33 / 36 on 22's....? Wouldn't have thought that would be good for the tyres.
My tyre fitter advised an extra 4psi to the 20" pressures, which ties in with a few other posts on here. I could be wrong, but mine are doing well with a good ride quality too. Have a nose around here, not worth wrecking good tyres for the sake of not reading a few earlier topics.
CDC Everybody is clinging on to their sanity….Some just hide it better than others….
Post #285187 Sat Jan 08 2011 10:28am
NickM
I go with 40 on my 22's all round....
Post #285188 Sat Jan 08 2011 10:32am
8 CDC
Yeah, 40 all round or 37 / 40 seemed to be what many have said worked well.
Post #285189 Sat Jan 08 2011 10:35am
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
Same here
Post #285190 Sat Jan 08 2011 10:48am
carlos50
I'm running 34 front & 37 rear in my 4.2 SC with 20" OEM wheels, they were at 30 all round when i bought it (2nd hand) and found a huge difference in the feel of the RRS. Is 34 / 37 still too low for 20" ?.
I always put mine up past what the manufacturer recommends anyway, do i need a touch more?
Post #285191 Sat Jan 08 2011 10:48am
