Parking ade
Help please front parking ade inactive long tone with flashing switch light is this the front sensor or can it be the rear any way of telling which sensor and if I find out and replace the faulty sensor myself will this take message away ?paul
Fri Dec 31 2010 1:21pm
ricknchi
hi there
The flashing light is indicating a fault on the parking aid system it could be a faulty sensor or wiring loom
How old is the vehicle?
Rear wiring looms corroding is not un-common
only other way is to check with diagnostic computer but remember if it is showing a sensor to be faulty it could still be the wiring to that sensor causing the fault so check wiring before replacing the sensor
Sun Jan 02 2011 7:32pm
ptwroofing
thanks the car s a 55 plate with 47,000 miles the place i took it wanted £55 plus vat each sensor and £60 plus vat labour per hour reckons 2 hours plus and normally 2 sensors and thats not main dealerpaul
Sun Jan 02 2011 9:07pm
ricknchi
what would be needed is not check on diagnostic computer to see which sensor is showing a fault, then remove that bumper and check the wiring to that sensor if the wiring is okay replace the faulty sensor and refit the bumper.
The prices you have been qouted seem reasonable but without the diagnostic check you will not know which sensor is faulty.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
