![]() | Home > Technical > hdc fault problem |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 ![]() ![]() ![]() |
If your getting this message on start-up it's a low / duff battery Cheers Paul
ptwroofing Member Since: 30 Dec 2010 Location: hertfordshire Posts: 38 ![]() ![]() ![]() |
Thanks do I need to replace the battery and is it safe to disconnect the battery or will I lose everything or get more dash messages thanks again Paul paul |
Get the battery checked first and then replace if it is duff / low.. When I changed mine I just lost the pre-set radio stations and clock time |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402 ![]() ![]() ![]() |
Mine has been doing this for 2 months, every time its started. I assume its the battery and will change it once the bad weather is behind us. Its never got any worse than a brief message, im lead to believe aslong as the message goes away on its own after a couple of seconds then your fine, its just the battery is low. |
