![]() | Home > Technical > Car wont start ! |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
At a guess from similar on D3 site battery is goosed, either on it's own or because alternator is similarly goosed. |
raymondnicol Member Since: 24 Dec 2010 Location: Scotland Posts: 8 ![]() ![]() ![]() |
do you think this has anything to do with the work they have already done or just wear and tear? much was it to fix your d3? you get no help from stratstone think the next car will be a chiquichento haha |
Afraid I'm a non techie so no idea, just a lot of similar problems at the mo with D3s, a RRS being a D3 in drag. |
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
thanks alot m8 |
the tensioner jumped it needed fixed what started of a fuel pump problem by an aa technician ended up a £7000 head sore . |
Silk purse from pigs ear. ![]() ![]() |
found out my problem it was a corroded wire in the harness hope it helps someone |
