Bobby
Lets get this out of the way so that we can all enjoy Christmas...
That's the TPMS Switch, BPB..
Quote:TPMS Switch
NOTE:
The TPMS switch is not fitted to NAS vehicles. NAS vehicles do not have the option to select target pressure modes.
The TPMS switch is a non-latching push button switch which is located in the centre console switch pack, adjacent to the DSC switch.
The TPMS switch is used by the driver to set the required target pressures for the vehicle, i.e. ‘light load’ or ‘heavy load’. The switch is used to toggle between the two modes.
The TPMS switch has a status LED, located in the face of the switch, which informs the driver when the ‘light load’ or ‘heavy load’ pressures are set. When 'light load' mode is set, the LED is illuminated. When 'heavy load' mode is set, the LED is extinguished.
The status LED has two-stage illumination, providing day or night time illumination levels. The illumination level is determined by the TPMS module, based on data received via the vehicle CAN interface.
The switch is used to change between the modes as required. The ignition switch must be in position II. If the TPMS is in the 'light load' mode, pressing and holding the switch for 4 seconds will change the target pressures to 'heavy load' mode. The LED will be extinguished, the message centre in the instrument cluster will flash 'TYRE PRESSURE MONITORING SET FOR HEAVY LOAD' for 3 seconds. This setting will remain until deselected by the driver.
To change from 'heavy load' mode to 'light load' mode, the ignition switch must be in position II and the switch must be pressed and held for 4 seconds. This will change the target pressures from 'heavy load' mode to 'light load' mode. The switch LED will illuminate and the instrument cluster message centre will display 'TYRE PRESSURE MONITORING SET FOR LIGHT LOAD' for 3 seconds. The 'light load' message will also be displayed at every ignition cycle.
Merry Christmas everybody!!!
Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Fri Dec 24 2010 1:41am |
