![]() | Home > Technical > Windscreen washer Motor |
| marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68
Hi Does anyone know where i can find the fuse for the windscreen washer motor? its not under the bonnet as ive looked loads of fuses there , but not for the washer. It was making its noise the other day but now it does not make a sound i know its frozen but the motor should still sound even if no water comes out Right?????? |
No! Mine have frozen and you can't hear the the motor when trying to engage. Fuse box is behind the lower glove box. RTFM! |
Cheers for that |
| smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81
just been sorting my frozen screen wash,got some warm tap water in a squirty bottle and sprayed it onto the jets on the bonnet and headlight jets.then flipped the bonnet and on the bonnet same side as water bottle the hose to the jets is slighly visible,sprayed warm water onto this and now windscreen wash works.simples |
Ill try that tomorrow had a little water skirting today but then stopped |
Yes i know it was two posts Im sure it said 5amp ill double check that Think you r right |
Hi all well got the water to work on the headlamp washers but nowt on the bonnet windscreen washers there was alittle trickle now nothing nor on the rear prity sure the pipes arnt frozen. Is there a seperate fuse for the windscreen washers ?? also the motor runs when you push the stick. ..My old Ford ranger has got just water in the bottle & they work.. |
| shuzzy Member Since: 02 Aug 2009 Location: West Yorkshire Posts: 143
My windscreen washer fuse keeps blowing. It is a 10A fuse which is number 11 if I remembr rightly behind the glovebox. Is a right PITA to change too if you got gorilla hands. |
| AJS Member Since: 25 Mar 2010 Location: OXFORDSHIRE Posts: 9
Hi All... Well finallly got to the bottom of why my washer jets would not work.. i must have tried to make them work when there was ice in the motor & it broke all the impeller blades off. Hence no water i took it to the local LR Dealer, their mechanic told me it was abitch of a job "The front wheel had to be removed the mud gaurd had to be totally removed then the motor could be accessed He said it would be a 30-45 min job & cost about £60.00. I bought the new motor of them£17.00.. stuck it on my mates ramp took 4 screws out at the front of the mud gaurd & pulled it back 8 inches left the wheel on ..motor for the windscreen pump was easily accessable changed the motors over, put the 4 screws back in & hey presto it works fine ..Total time to do the job was 12mins.. Ps There are 2 motors for the washers 0ne for the lights & one for the front & rear screen
| Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515
Nice one. Well done ! |
