![]() | Home > Technical > Tbh heater fumes in cabin |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
I have smelt this first thing when manoeuvring i.e. turning around/reversing but disappears when I set off |
AlexMckie Member Since: 26 Nov 2009 Location: Devon Posts: 174 ![]() ![]() ![]() |
Not a lot can be done apart from putting your 'recirculation' button on when idling... It's a flaw of the FBH not venting out of the engine bay...
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Me too; while sat in traffic. It seems to go once the car is moving again. FF 4.4 V8 Soooo looking forward to this bad boy Ex 2006 RRS SC - garbage Ex 2016 135i M Sport - dream car Ex 2003 RS6 Avant - piece of cr*p Ex 2014 320d X Drive, M Sport Touring - ok I guess Ex 2007 RRS TDV8 - bloody loved it EX 2007 FL2 XS - not so bad |
wackyjim Member Since: 12 Nov 2009 Location: Tayside Posts: 265 ![]() ![]() |
Also check there is not an actual diesel leak from the high pressure fuel pump or a leaking injector which is spraying onto the manifold....it can give similar fumes and as it evaporates once it hits the manifold there are no real tell tale drip signs below the car |
sworks Member Since: 28 Nov 2010 Location: Inverness Posts: 5 ![]() ![]() ![]() |
Thanks very much for the feed back does the FBH (my error) keep on running when the engine is switched I know it runs when the engine is off
