![]() | Home > Maintenance & Modifications > NSF "Squeaking" after turing off the engine |
I'm getting a squeak squeak squeak noise from the front left of the car that carries on for approx 10 seconds after the engine is turned off (probably squeaking all the time but with the engine going it's being drowned out)
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Could it be the air suspension settling after the car is turned off? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Like a compressor bearing or something like that... hmmm could be.. RRS gone
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
The FBH is there too could it be that 16 model year yulong white autobiography
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Mine does exactly this too. Ive no idea why! FF 4.4 V8 Soooo looking forward to this bad boy
It's your EGR valves cleaning themselves
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
I double took then - thought you'd come back to the fold with a RRS until I saw the date |
outback4x4uk Member Since: 06 Oct 2011 Location: shropshire Posts: 13 ![]() ![]() ![]() |
What you might find it to be is the variable vane turbo actuators cycling, they do it every time the ignition is turned on and off about 5 times each if memory is correct.
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 ![]() ![]() ![]() |
Is there a remedy for it? Current 2010 RRS TDV8
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
yes, ear plugs |
What about 2 stroke in the tank?
Well if its the actuator rod joints then yes there's a diy and dealer fix, if its the EGR valves as awd man suggested then no quick diy fix, but they can be replaced.
Thanks outback |
