![]() | Home > Technical > 2 Stroke Oil added to diesel |
| 1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530
So glad it works, I am now on my third tank of the oil diesel mix and it is working really well. |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
300 ml in a tank full (85lt) is too much, next time you see a two stoke m/c touch the inside of the exhaust - if you really are going to do it; 100ml is OK - 150 ml max. |
| flydive Member Since: 17 May 2007 Location: South Posts: 1213
Well, according to YF on the fl2 site the rate should be 1:200, so 300 ml is even a bit on the low side.
It's a judgement call.
| lilweliwell Member Since: 27 Nov 2010 Location: Dublin Posts: 20
I'm going to join you guys...just quick question...i bought 2 stroke oil semisynthetic API TC, JASO FB - Red mix. What does it mean RED MIX? Is it OK? |
| JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113
Hi lilweliwell
Hi Jim,
Hi lilweliwell
I am asking just because I am second owner and don't have any clue if is there or not...I will use rather "FC rated" 2 stroke...just in case. Thanks anyway |
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
It is already some time ago that I read most of the articles, and what I noticed was that a small mixture of Bio diesel would already give a much better effect.
By accident I empty 500 ml bottle of 2 stroke in my tank...i didn't measure 300ml at home and on the petrol station i had phone call and completly forgot what I am doing....my bad. Than I filled full tank. Is it big deal? Can this cause some damage? |
You should be fine as some say 300ml or 400ml to a full tank, so I wouldn't worry, maybe top up with just diesel when it is quarter full. Let me know how you get on. |
Hi
So we've seen recommendations on this thread go from 200ml to 500ml; why not go on and add a litre, that'll be about 80:1 !!!
