Home > General > extended mode trick
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
extended mode trick
there is a trick to get into extended mode, i was shown on the LR off road day.. anyone remember it?
Post #282035 Sun Dec 05 2010 10:11pm
MAW
Tim In Scotland posted on it - search his posts - I cannot recall what was involved Thumbs Up
Post #282058 Sun Dec 05 2010 11:41pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
On a reasonably level surface, engine running and in Park:
1 Select the Terrain response program you need (generally Rock Crawl)
2 Place the car in off-road height
3 Get the LR jack and place it under one of the jack points - raise it until it firmly sits under the chassis rail
4 Get in the car, close the door and press the EAS switch to lower to normal mode
5 Car will sense the obstruction and raise to extended mode
6 (Optional) simultaneously hold the brake pedal down and press and hold the EAS switch up for 5sec. Car will raise to Emergency mode.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #282071 Mon Dec 06 2010 1:32am
