![]() | Home > Technical > EGR Valve possible problems |
EGRs on a car this age could well be a problem but you're likely to get an engine warning if there's a problem with them. Drop the car off to a dealer to check because it could be a number of things. 2005 Zambezi TDV6 - Gone but not forgotten
| kupid0n Member Since: 26 Jun 2010 Location: oradea Posts: 30
hey! had the same problem....does it smoke when you floor it?mine did....horribly....had a hole in the intercooler....replaced it.....problem solved, but a month later the hose between the intercooler and the intake just "exploded" causing the same problem....replaced that too and now it runs like a champ. have a mechanic check your intake pressure because black smoke and lack of power can mean only one thing....bad air/fuel mix.
| Brennie Member Since: 03 Oct 2010 Location: west sussex Posts: 8
Hi kupidOn smokes when first started and when i'm driving it smokes when it changes gear there's a real lack of power momentarily. Thanks |
Hi been to land rover main dealer today and N/S EGR valve is not working properly so glad its only that! But there is one thing will i run 2 stroke oil in it again i think not!!!! |
| All times are GMT |
