Home > Technical > Raising/Lowering suspension
Nice But Dim
So i played with the button that raises suspension while sitting in the car while the wife went to get my beer from the off licence Razz and it was like i was on a ride at a theme park Confused
front nearside lifted then rear offside then all four corners joined in for a moment and then jiggered around before stopping, felt dizzy.
Wife arrived and said the left side of the car is drooping, checked my beer she had been sent in for and all was accounted for so i checked the droop myself and the left of the car is lower than the right in access mode.
Suspect the car should not be tilted to one side when in access mode but is the jerky suspension lift common?
P.S i did not at anytime introduce my alcoholic beverage to any part of the cars fluid systems.
Post #280534 Thu Nov 18 2010 12:22am
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
Sounds like it could be a ride height sensor, there was a TSB issued for this fault.
Jim
Post #280538 Thu Nov 18 2010 1:16am
Nice But Dim
Jim
Thanks Jim
Its due to be booked in to be looked at, but is the raising from access to standard height suppose to be so jerky? or should i be mentioning to my dealer while looking at the ride height sensor, to check compressor to?
Cheers.
Post #280817 Sun Nov 21 2010 10:48pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Nice But Dim wrote:
Jim
Thanks Jim
Cheers.
should be smooth mate, no jerkyness what so ever on mine
Post #280818 Sun Nov 21 2010 10:54pm
carlos50
Mine is smooth but does rear first then front.
No messages / issues but it seems that how it raises on mine.
Carl
Post #280843 Mon Nov 22 2010 1:46pm
Nice But Dim
Thanks Guys
Obviously mine needs checking then, hoping they can fix the jerkyness at same time of the lean while in access mode, may be related.
Post #280861 Mon Nov 22 2010 5:05pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Carl
Your suspension works as it should be: first rear then front. Also, keep in mind that you have two separate devices for rear and front suspension. The front has its own reservoir, not sure what the rear has, but its different. Sometimes, front reservoir needs to "re-charge" and therefore it may lift the front at a much slower rate than the rear side. That should not be of any concern as it is also, you guessed it, normal. This usually when you leave the car parked for some time. So do not worry, your suspension is fine. Thumbs Up Vadim A.
Post #280898 Tue Nov 23 2010 1:42am
Bobby
Vadim wrote:
.. Also, keep in mind that you have two separate devices for rear and front suspension. The front has its own reservoir, not sure what the rear has, but its different. Sometimes, front reservoir needs to "re-charge" and therefore it may lift the front at a much slower rate than the rear side. That should not be of any concern as it is also, you guessed it, normal. This usually when you leave the car parked for some time. So do not worry, your suspension is fine. Thumbs Up
Not sure of the MY2010 system but ...
Quote:
The dynamic suspension system is a four corner air suspension system which is fitted as standard to all models. The dynamic suspension system is electronically controlled by an air suspension control module which controls the air supply unit, reacts to inputs from four height sensors and distributes air around the system via valve blocks.
The main air suspension system components are:
** Air suspension control module
** Air supply unit
** Four height sensors
** Three valve block assemblies
** Reservoir
** Air harness
** Four suspension air spring damper modules.
The four corner air suspension system maintains the vehicle height under all operating conditions by controlling
the mass of air in the air springs. The air suspension control module uses signals from the four height sensors to maintain the correct suspension height. This is achieved by operating pneumatic control valves to increase or
decrease the mass of air in the air spring damper modules.
Its all one device. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #280901 Tue Nov 23 2010 5:27am
Nice But Dim
Thanks Guys
Very informative...i love this site. Thumbs Up
Post #280908 Tue Nov 23 2010 9:25am
Vadim
** Air supply unit
** Reservoir
** Air harness
Its all one device.
Hi Bobby,
As matter of fact it is two separate devices on MY2010 models. But you are absolutely right, pre-2010 models had different design in this respect. I have an email from LPR regarding this matter which explains why front suspension can be slower than the rear, and the reason is as I explain above.
Regards, Vadim A.
Post #280948 Tue Nov 23 2010 6:37pm
Bobby
Hi Vadim,
This is most interesting.
I am aware that that on the MY2010 models there is an addition (improvement?) to the suspension system - continuously variable damping, known as Adaptive Dynamics which is standard on 5.0 S/C variants and is an optional on 5.0 N/A and TDV8 variants.
The basics (design) I thought were still the same, as I mentioned above.
So there are two reservoirs now - one for the front and one for the back? Completely two devices?
Could you find out more?
Thanks. Malaysia Boleh!
Post #280994 Wed Nov 24 2010 3:51am
Vadim
Hi Bobby,
I will try to find out more, no problemo! Thumbs Up Vadim A.
Post #280995 Wed Nov 24 2010 4:07am
Vadim
Here it is Bobby,
Copy and paste from LR factory report:
THE FRONT AIR SPRING PRESSURES ARE HIGHER THAN THE REARS (10 TO 12 BAR VERSUS 5 T 8 BAR) SO WHEN THE RESERVOIR STARTS TO BECOME DEPLETED, THE REARS WILL GO UP QUICKLY (USING THE RESERVOIR) AND THE FRONTS WILL RAISE UP SLOWLY USING THE COMPRESSOR. IF THE SUSPENSION SYSTEM HAS HAD SUFFICIENT TIME TO RECHARGE THE RESERVOIR (TYPICALLY 5 MINUTES OF ENGINE RUNNING FROM A COMPRESSOR COLD START) THEN THE SUSPENSION FRONT AND REAR WILL RAISE QUICKLY. THE INSTRUMENT PACK MESSAGE HAS CHANGED AT 10 MODEL YEAR FROM “SUSPENSION LIFTING SLOWLY”, TO “VEHICLE RAISING IN PROGRESS”.
Seems I got it a bit wrong... Embarassed Whistle there is only one reservoir, however it certain circumstances the front side will be raised using compressor. Vadim A.
Post #280996 Wed Nov 24 2010 4:30am
Bobby
No worries, understood! Thumbs Up Malaysia Boleh!
Post #280999 Wed Nov 24 2010 6:08am
