![]() | Home > General > Buying an RRS, advice appreciated |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Welcome to the Forum |
RoyF Member Since: 16 Nov 2010 Location: Berkshire Posts: 5 ![]() ![]() |
Thanks for the message Enjin,
rajhirani Member Since: 05 Mar 2009 Location: london Posts: 53 ![]() ![]() ![]() |
Good tip, thanks for that Raj......I want to make sure I do my homework and get the best spec I can for the money. Unfortunately budget is going up and up all the time !!!. |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Make sure you get a decent warranty, LR's ain't exactly the most reliable things in the world. |
just need to post 2 messages to be able to send a PM....
Thanks DSL, that why I'm convinced the only route to go is down the LR Main Dealer Route for a good 'Dealer Approved Warranty' and add the second year on. Are there are down points with the LR Used Approved Warranty do you know?
Certainly on the D3 site the LR warranty don't get a good reputation, the cheaper one (select ISTR) is described as as useless as a chocolate teapot! I run 2 06MY D3s and have warranties through Warranty Direct, others use Warranty Wise, AA, etc. The reason I went for WD (after my most excellent Tesco warranties run out) is they cover wear & tear and have a good history of paying up. So far they have been very good and covered what the promise, my D3 has just had a worn out wheel bearing replaced today. Pays yer money etc, just don't run one of these veeeeeehickles without one as they can be complete cash cows. |
