![]() | Home > Technical > Auto Lights Problem??? |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Weird or what, had exactly the same on road up the M6 & M74 past Carlisle & up to Abingdon on Saturday!!! Switched to OFF & used ON when started to get dark, though switched to Auto to check working and they were. |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Very strange. Turned off and back on but still on. Haven't tried after car turned off yet as it was dark by the time I got in. Will try again tomorrow and see if it's reset. |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Happens to me every now and again. They often stay on when exiting a tunnel for example even in bright daylight. I just ignore it now. FF 4.4 V8 Soooo looking forward to this bad boy
They do switch they lights on when very low light angle but bright, maybe gets confused. Hey they are LRs, we're not meant to understand. |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Same with me today |
Least it's not just me.
If same as on D3 (a RRS being a D3 in drag) there are sensors in the rear view mirror looking through windscreen. Will give mine a clean tomorrow once it's got above freezing. |
Thanks DSL |
![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
On Sat would have added early afternoon sunshine with the odd cloud to that list. Was deffo on when it should have been off. |
Same with mine early afternoon, sunshine and definatly not dark enough for them to be on. Wonder how many other people this has happened to and they haven't even realised due to it not being that easy to see that they on in the day via the dash. |
I've got aux lights so when on I get an orange light on the switch when lights are on. From my07 the D3s have a green light in the dash to say they are on, don't know about RRSs. |
Probably the same. I've probably just never noticed it. |
Mind you these are Land Rovers, once the get to a certain age you spend the whole drive using The Force to feel for the next thing going wrong. If this is all I've got to worry about (which it isn't) then I'm getting off lightly!! |
