Home > Technical > Smoke from engine TD V8
mexi
Italy 2008 Range Rover Sport TDV8 HSE Zermatt Silver
While a was driving an ENGINE FAILURE appared with loss of power,like I was driving with only 1/2 cilinder.
Smoke from the engine was coming out with smell like the engine was GONE !
I turn the engine off,I waited two minutes turned it on again and everithing was ok again,drove for 700 km with no problems.
Any suggestions ??
Thanks
Mexi
Post #279718 Mon Nov 08 2010 12:08pm
Get it straight into a service centre. 2005 Zambezi TDV6 - Gone but not forgotten
Post #279720 Mon Nov 08 2010 12:11pm
mexi
Did it already.....waiting for an answer.
The problem will be if they say " we could not find any problem" .
Will see......
Mexi
Post #279735 Mon Nov 08 2010 3:15pm
DSL
Turbo issue? Sounds like a classic TDV6 turbo failure symptoms (except the start up again & all well), maybe the TDV8 does it the same way?? Shocked
Post #279736 Mon Nov 08 2010 3:21pm
Old Stager
United Kingdom 2010 Range Rover Sport TDV8 HSE Zermatt Silver
Does it have a particulate filter (DPF)? 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
IN THE GARAGE: BMW i8 - the mid-life crisis continues and it's great fun.
Post #279787 Mon Nov 08 2010 11:21pm
mexi
The service dep. called me,there was a faulty sensor of the turbine and something also related with the DPF.
I still don't understain why there was burning smoke coming out from the engine !
I will ask better when I will pick up the car.
Mexi
Post #279806 Tue Nov 09 2010 10:41am
Old Stager
It may have been the DPF regenerating. I had this happen once on my 7 Series BMW - there was a cloud of dense smoke from under the car, accompanied by an awful smell (I thought the car was on fire!). Apparently this is normal behaviour whilst the DPF is regenerating - it usually happens at high speed so the smoke & smell is not noticable.
Have you done a lot of short trips recently? This can make it much worse. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #279807 Tue Nov 09 2010 10:49am
mexi
Normally I use that car in the city,when that problem appears,I was driving on the freeway for about 400 km on high speed 160/170 km per hour,that I stopped for lunch,after that .....it happens and yes,the smell was like rubber and oil burning.
Also why the smoke was coming from the engine and not from exhausts ??
Thanks
Mexi
Post #279812 Tue Nov 09 2010 11:09am
Old Stager
Not sure why the smoke doesn't come from the exhaust, sorry. I guess it just vents off from wherever the DPF is located. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Post #279814 Tue Nov 09 2010 11:11am
mexi
Thank you Old Stager.
By from Rome.
Mexi
Post #279815 Tue Nov 09 2010 11:19am
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
Maybe could be a failure EGR (valve,pipe or falange bolt leaking)
Post #279869 Tue Nov 09 2010 10:55pm
mexi
Got my Range back,they said the problem was : the sensor that regulated the temperature of the DPF.
By
Mexy
Post #280020 Thu Nov 11 2010 5:14pm
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
Good you got it fixed
Post #280021 Thu Nov 11 2010 6:01pm
