Home > Technical > Range Rover Sport Bonnet Open Fault
Did this fix your fault?
Yes
100%
 100%  [3]
No
0%
 0%  [0]
Total Votes: 3
easyrideruk
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Hello all,
I recently went for a weekend trip, only to go through a massive water puddle at about 50 MPH. Shocked Later the next day, l parked the car, returned to it and started it up. Immediately l was presented with the "Bonnet Open" notification. Big Cry Despite opening and re-closing my bonnet several times, the error remained. Censored
Here is a video clip of how l fixed it. Rolling with laughter Please excuse the audio as this is my first video compilation.
All thanks to Land Rover Assistance On-call Technician Thumbs Up EasyriderUK
Post #279774 Mon Nov 08 2010 8:39pm
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Very usefull tip thx.
And then as is always the case with You Tube... I end up spending another 30 minutes watching related video's that all tend to merge into a totally different subject! Laughing
Post #279801 Tue Nov 09 2010 8:46am
Jimmy_75000
Thumbs Up Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #279856 Tue Nov 09 2010 8:42pm
Lutch
Trinidad And Tobago 2009 Range Rover Sport TDV6 HSE Alaska White
Bonnet error message
Great tip and video. Thank a million as this simple error caused me much distress with the message constantly blinking on the dash as well as the loud horn sounding every time I locked the doors from the remote upon exit. This always made my 2 year old bawl cause it's so loud.
For some of us it may be difficult fitting our fingers as the video prescribed. I found that I gained access (to the spot being described in the vid) easier by entering just in front of the yellow bottle cover. This is supped to be the washer fluid if I'm not mistaken.
There's a larger opening just in front of that yellow cover where you can fit your fingers through a bit easier toward the latch. Compare the left and right latches and you would notice the latch on the driver side (right) has a type of module clipped onto the bottom of the latch. This I believe has something to do with the problem.
Now I was expecting to feel or hear a noticeable click, but in my case it was barely noticeable. I took my fingers and basically pressed up that module. There was an ever so slight movement upward to the latch base.
I started her up and problem solved. Greatest tip!! Live love laugh...
2009 Range Rover Sport HSE in Alaska white.
2008 Evo X - 700awhp
Post #283516 Sun Dec 19 2010 11:09pm
Mail Order Ride
Brilliant
Top hit on Google-ing "RR Sport bonnet open"
Dont know why I didnt just check in here first
cheers!
Post #324645 Sat Dec 10 2011 11:55am
Supacat
Anyone know the technical detail behind this fix? What are you pressing?
Post #324659 Sat Dec 10 2011 3:51pm
anothermoneypit
Same here... Post replacement alternator replacement... Wonder if theb56 plate is any different... Soon find out....
Post #377419 Mon Mar 18 2013 10:43pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Great video!
My alarm has been going off at odd times over the last 3 weeks and I put it down to someone setting their car alarm and subsequently setting mine off.
I then noticed that I was getting a "Bonnet open" message which was why I was getting that annoying horn when re-alarming.
I watched the vid and think it sorted it out straight away but I didn't hear or feel a "click".
I just applied pressure to it, closed the bonnet and did a system check.
No more message so many thanks! Thumbs Up
Gaz I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #471219 Thu Aug 27 2015 7:47pm
Gaz
.....update.....didn't work.
Still getting alarm and message problems. I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #471884 Thu Sep 03 2015 7:04pm
Change the switch/latch. £25 and 20 minutes and it's done properly. Hardly worth trying clever shortcuts really. 2012 SDV6 - it's missing a couple of cylinders
Post #471895 Thu Sep 03 2015 8:11pm
RainHard
South Africa 2009 Range Rover Sport Supercharged Alaska White
look inside the catch (from the top) there is a "silver" switch plate that needs to be cleaned. electrical cleaner and a ear bud does the trick
Post #473378 Wed Sep 16 2015 6:10pm
