![]() | Home > General > Recovery of an RRS with 2 wheels on ground |
WOODY179 Member Since: 30 Nov 2005 Location: Derbyshire Posts: 163 ![]() ![]() |
Posted this on the D3 site but not had any answer.
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
Will do the diff in. |
CAUTION: Suspended towing of this vehicle MUST NOT be attempted, if 4 wheel towing is not possible, vehicle must be recovered on a suitable trailer. Malaysia Boleh!
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
After a transfer box failure on a Stonefield, I had to remove the rear halfshafts for a suspended tow of the the vehicle from the M25 back up to Newcastle.
Thanks for the replies everyone, I know that the manual states 'under no circumstances should the car be towed with 2 wheels on the ground' - just wondered what the potential damage could be. |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 ![]() ![]() ![]() |
i would'nt have thought any damage would be done if the propshaft was removed. andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127 ![]() ![]() ![]() |
I would have thought a tow with two wheels only lifted would cause significant damage to the centre differential - especially as it supposed to be limited slip. With the front wheels anchored and the rears on the road it will spin very fast! Not knowing a great deal about RRS differentials I would have thought there is ample opportunity for it to lock up in such circumstances and be essentially destroyed - but the rear wheels would probably also lock up as a result. I certainly wouldn't try it to see what happened! |
Saw the recovery and the prop shaft was not removed, the car was reversed off the drive, driven on to the front wheel lift of the recovery vehicle where the front wheels were secured. Recovery vehicle then reversed up a side road and drove off. |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
The centre diff isn't designed to take up the difference between the a stationary front prop and the rear prop rotating at "normal" speed. Like this site? Buy some RRSPORT goodies to show your support! |
Thanks Martin & everyone else for you replies, It was a friend of mines car so I'll now be able to tell him what the potential damage could be |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
As you saw where the car came from maybe a nice gesture would be to knock on the guys door and tell him what you saw and what damage may have been caused to his car by the ignorant tow truck driver! At least he can have it checked out and repaired at their cost rather than his own. Just a thought for a good deed towards another RRS owner ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
already done so Endjin |
Top Man |
